Does anyone have any advice on moving the headlight in its aperture? I'm not talking about beam alignment, but the physical location: in my car I notice that the gap above the light is too large, so the whole thing needs to come up a couple of millimetres. (I'm pretty sure the bonnet is aligned OK.)
I've had a poke around, and found that the inner and outer clamping screws have an adjusting collar at the bottom (reverse-threaded) but raising these didn't directly move the front of the glass in proportion. And quite possibly messed with the beam direction. I'll see when it gets dark. :?
I'm wondering if it's the two plastic prongs which engage with the bottom of the light assembly. I see from the diagram that they're screwed on (Part 15 & 16), which I didn't notice when I had the headlight out. If they have an oval screw hole for vertical movement, then I think that would do the job.
I'll have another look some time soon, but it's a faff taking the headlight out and putting it back. Or I could just learn to live with two millimetres of panel gap.
http://www.realoem.me/Audi/RDW/ATT/2007/609/R/9/941/941000
