21 - 40 of 214 Posts
Stolberg said:
Sporadic tail light failure message on start-up, drive a mile or so, press the break, signal disappears and tail light comes back on again. Amassive pain!
Damn........
Started getting this on Monday.......
It is really easy to do (the OEM repair), as long as you have right tools and components.
Took me half an hour to do.
You'll need:
Wire strippers, Wire cutters, Drill, Connector Crimper Tool (I used this rather than soldering iron), Electrical Tape, Thick 1m length of Earth wire depending on whether you are attaching to the bolt under the car or the bumper bracket next to the light fitting, wax or grease to protect earth connections from water.
1-off Male and 1-off female bullet connector - So you can detach earth wire when removing light cluster in future. (wing nut is another option as per top of this feed).
2-off connectors. The connector needs to be big enough to fit over the bolt you are connecting to (on car and bolt fitted to light fitting).
4-off washers and one nut and bolt. The smaller the better. I will try and take a picture in the next day or so to show how mine looks.
Trust me, I am a real novice with this sort of thing, but it is very simple to do.
Nightmare. Did you put the connect to underneath the car or next to the light cluster/bumper bracket?
I guess you cleaned up the area you connected to, so that it was metal to metal (no paint or muck in between). And you placed the connector inside the light to the outer most metal wire run as per the pictures above?
[smiley=bigcry.gif]
Discussion starter · #25 ·
Both inner indicators giving up seems too much of an coincidence. Try the rear lights again without the additional earth connectors, check the bulbs and check how they sit in the bulb holder.
I don't see a connection with the fog light. Perhaps it is broken?
I actually fed it through into the boot and used the earth point in the rear corner, which I think is where the rear lights earth. I cleaned the contacts.
It's definitely the right 'wire' on the light, as I traced it myself before checking this how-to.
The new earthing has noticeably improved the light brightness, as I tried with and without the new earthing. Tested the indicators with and without too, with no luck.
I thought that the fog light may be unrelated, just seemed a big coincidence. I just haven't had a chance to check yet.
Thanks for the help and the initial how to. :)
Discussion starter · #27 ·
So you've done the right thing then, lights are brighter so we're sure the earth connection is working.
You didn't accidentally forgot to re-attach the fog-light earth connector? I'd expect that one to be shared with the rear light units.
Greetings from Luxembourg!
The DIS bulb failure warning has popup a couple of times the last months, however only for a few seconds after I start up the engine and maneuver the car in the garage (most likely it comes up when I engage/disengage reverse gear in combination with the brakes).
So, after connecting VCDS the following fault code has been recorded:
Address 09: Cent. Elect. Labels: 8P0-907-279-30-H.lbl
Part No SW: 8P0 907 279 K HW: 8P0 907 279 K
Component: Bordnetz-SG H54 2501
Revision: 00H54000 Serial number: 00000007227823
Coding: 01040E8280141C00471800001800000000095E075C210802000000000000
Shop #: WSC 01236 785 00200
VCID: 458AB0230C23B836E81-8010
Subsystem 1 - Part No: 8J1 955 119 Labels: 1KX-955-119.CLB
Component: Wischer AU354 H07 0060
Coding: 00064784
Shop #: WSC 01236
1 Fault Found:
00984 - Left Tail Light (M4)
012 - Electrical Fault in Circuit - Intermittent
Freeze Frame:
Fault Status: 00101100
Fault Priority: 2
Fault Frequency: 3
Reset counter: 177
Mileage: 34372 km
Time Indication: 0
Date: 2013.12.09
Time: 09:58:00
Freeze Frame:
ON
Voltage: 14.30 V
OFF
ON
OFF
OFF
OFF
From the symptoms I suppose that I have to do the modification suggested and avoid of course Audi stealers. My questions is the following: should I do this for the left rear unit (as per VCDS fault code), or the rear unit (as per the guidance in the first page), or even in both units???? The wheel is on the left side :)
Thanks a lot for your help!
Discussion starter · #29 ·
Each unit has its own earth connector. So with yours the left one needs to be fixed. I'd fix the right side too as most likely that one will fail when it's cold and wet, if you see what I mean.
I had this fault on the DIS today, and i would like to try the non OEM repair, but the pictures on the guide are gone. I know is an ancient post but the issue seems to be alive and kicking...
Does anyone have the pictures?
Since this is a common occurrence on MK2 TT, maybe a DIY on the KB would be a good idea :)
The guide is in the knowledgebase, complete with picures (I dont know why they're not showing in this thread though).
Sent from AutoGuide.com App
TT-driver said:
Restored them, now pointing to the location where Brittan saved them :D
[smiley=thumbsup.gif]
Yes, I've had problems with imageshack and deletion of photos. It took a lot of time to find, re-host and restore the correct pictures.
Originally I put the KB pictures on imageshack to make their locations distinct from my photos in my photobucket account, but now I simply run 2 photobucket accounts.
Discussion starter · #37 ·
The connectors and pins are available separately through the dealers according to various posts on various forums. I'm afraid I don't have the part numbers though.
Hi guys!
I have a small doubt, and this is regarding the original cable. Should it remain the same way it is now? Just add the additional earth wire and I'm ready to go, right?
Thanks for the help, I think this will be my life saver!
Yes that's right, the original wiring remains the same.
Effectively the original earth wire and the supplementary earth wire are in parallel.
